Gönderen Konu: 20MHz to 18GHz RF and Microwave Pin Diode Switches  (Okunma sayısı 5549 defa)
Çevrimdışı TA7MKS
« : 26 Haziran 2014, 14:55:05 »
     Corry Micronics offers a complete line of RF switches. The RF switches are controlled by pin diodes that cover a frequency range of 20MHz to 18GHz. The switches are offered as either the reflective or absorptive style RF switch. Many of our RF switches have been installed in communications systems, test equipment, filter and antenna selectors. Switches are designed to be TTL compatible. The RF switch series are also designed to have great port to port isolation from 55dB to over 80dB.
 tercüme için vaktim olmadı ama amatör arkadaşlarımın işine yarayacağını düşünüyorum
