Gönderen Konu: UK/EI DX contest 2016 (SSB)  (Okunma sayısı 10738 defa)
« : 17 Ekim 2016, 19:38:11 »
Log yükleme adresi : http://logs.ukeicc.com/cgi-bin/hfenter.pl?Contest=DX%20CW%20Contest
Bölgesel kod listesi
AB - Aberdeen - GM
AL - St. Albans - G
AN - Antrim - GI
AR - Armagh - GI
BA - Bath - G
BB - Blackburn - G
BD - Bradford - G
BH - Bournemouth - G
BL - Bolton - G
BM - Birmingham - G
BN - Brighton - G
BR - Bromley - G
BS - Bristol - G
CA - Carlisle - G
CB - Cambridge - G
CE - Clare - EI
CF - Cardiff - GW
CH - Chester - G
CK - Cork - EI
CL - Carlow - EI
CM - Chelmsford - G
CN - Cavan - EI
CO - Colchester - G
CR - Croydon - G
CT - Canterbury - G
CV - Coventry - G
CW - Crewe - G
DA - Dartford - G
DD - Dundee - GM
DE - Derby - G
DG - Dumfries - GM
DH - Durham - G
DL - Darlington - G
DN - Doncaster - G
DO - Donegal - EI
DR - Derry/Londonderry - GI
DT - Dorchester - G
DU - Dublin - EI
DW - Down - GI
DY - Dudley - G
EC - London EC1-4
EH - Edinburgh - GM
EL - London E1-18
EN - Enfield - G
EX - Exeter - G
FE - Fermanagh - GI
FK - Falkirk - GM
FY - Blackpool - G
GA - Galway - EI
GL - Gloucester - G
GS - Glasgow - GM
GU - Guildford - G
GY - Guernsey - GU
HA - Harrow - G
HD - Huddersfield - G
HG - Harrogate - G
HP - Hemel Hempstead - G
HR - Hereford - G
HS - Outer Hebrides - GM
HU - Hull - G
HX - Halifax - G
IG - Ilford - G
IM - Isle of Man - GD
IP - Ipswich - G
IV - Inverness - GM
JE - Jersey - GJ
KA - Kilmarnock - GM
KD - Kildare - EI
KE - Kerry - EI
KI - Kilkenny - EI
KT - Kingston on Thames - G
KW - Orkney Islands - GM
KY - Kirkcaldy - GM
LA - Lancaster - G
LD - Llandrindod Wells - GW
LE - Leicester - G
LF - Longford - EI
LH - Louth - EI
LI - Limerick - EI
LL - Llandudno - GW
LN - Lincoln - G
LO - Laois - EI
LP - Liverpool - G
LS - Leeds - G
LT - Leitrim - EI
LU - Luton - G
MA - Mayo - EI
ME - Medway - G
MK - Milton Keynes - G
ML - Motherwell - GM
MO - Monaghan - EI
MR - Manchester - G
MT - Meath - EI
NE - Newcastle upon Tyne - G
NG - Nottingham - G
NL - London N1-22
NN - Northampton - G
NP - Newport - GW
NR - Norwich - G
NW - London NW1-11
OF - Offaly - EI
OL - Oldham - G
OX - Oxford - G
PA - Paisley - GM
PE - Peterborough - G
PH - Perth - GM
PL - Plymouth - G
PO - Portsmouth - G
PR - Preston - G
RG - Reading - G
RH - Redhill - G
RM - Romford - G
RO - Roscommon - EI
SA - Swansea - GW
SD - Sheffield - G
SE - London SE1-28
SG - Stevenage - G
SI - Sligo - EI
SK - Stockport - G
SL - Slough - G
SM - Sutton - G
SN - Swindon - G
SO - Southampton - G
SP - Salisbury - G
SR - Sunderland - G
SS - Southend on Sea - G
ST - Stoke on Trent - G
SW - London SW1-20
SY - Shrewsbury - G
TA - Taunton - G
TD - Tweed - G/GM
TF - Telford - G
TI - Tipperary - EI
TN - Tonbridge - G
TQ - Torquay - G
TR - Truro - G
TS - Teeside - G
TW - Twickenham - G
TY - Tyrone - GI
UB - Uxbridge - G
WA - Warrington - G
WC - London WC1-2
WD - Watford - G
WF - Wakefield - G
WI - Wicklow - EI
WL - London W1-14
WM - Westmeath - EI
WN - Wigan - G
WR - Worcester - G
WS - Walsall - G
WT - Waterford - EI
WV - Wolverhampton - G
WX - Wexford - EI
YO - York - G
ZE - Shetland Islands - GM
« Son Düzenleme: 17 Ekim 2016, 19:51:07 Gönderen: TA5FA »
Ynt: UK/EI DX contest 2016 (SSB)
« Yanıtla #1 : 17 Ekim 2016, 19:58:59 »
2015 katılımcılarımız
TA4AKS
TA2AGO
TA2AKG
TA4OSK
TA2OTT
TA4ASO
TA5BS
TA3EP
TA1MRT
YM4KT
TC4A
TC5A
Çevrimdışı TA2TC
« Yanıtla #2 : 17 Ekim 2016, 22:56:45 »
İnfo için teşekkürler Mehmet Bey. Mesaimiz müsait olursa muhakkak katılacağız. 73
« Yanıtla #3 : 21 Ekim 2016, 19:01:10 »
Not:Yarışma saati başlangıç ve bitişinde il dışında olacağım :-(  Yarışmaya katılamıyorum 73.
« Yanıtla #4 : 22 Ekim 2016, 11:58:01 »
İngilizceyi iyi biliyorlar :) O yüzden karşınızdaki bir şey söyleyince "acaba ne demek istedi" diye düşünmeye gerek kalmıyor. Propagasyon şartları umarım daha iyileşir, yarışmada başarılar dilerim.
« Yanıtla #5 : 23 Ekim 2016, 14:09:29 »
Şartlar çok kötü. Dün zorunlu olarak istasyondan uzaktım. Bugün ise 3 Rus 1 Luxemburg istasyonu ve sıfır UK/EI...  73 Mete TA3EP.
Çevrimdışı TA2ANL
« Yanıtla #6 : 23 Ekim 2016, 14:45:28 »
Haklısınız, ben sizden biraz daha şanslıymışım; toplam 3 tane ingiliz istasyona denk geldim, 2'si ile görüşebildim, 3.'nün raporunu alana kadar kayboldu gitti. Geri kalanlar hep ruslar ve ukrayna'lı istasyonlar...
İyi haftasonları..
Tolga Anıl
« Yanıtla #7 : 23 Ekim 2016, 14:47:31 »
Evet üstadım ben de o Luxemburg istayonu ve bir UK istasyonu dahil 20 QSO yapabildim. İnşaallah haftaya da böyle olmaz. Bu arada Avrupa tarafi böyle kötü iken Asya tarafı güzeldi dün ve bu gün Nepal DX peditionundan 3 farklı istasyonu 21 ve 24 MHz'de  (rtty) yakalayabildim.
73...
« Yanıtla #8 : 23 Ekim 2016, 16:20:52 »
DİKKAT!
Yarışmaya log gönderme süresi çok kısa, bugün sona eriyormuş, hatta şu anda yarım saat kalmış!!!
Yarışmaya katılan ama log göndermeyen varsa lütfen hemen göndersin. Ben de alışverişe çıkmıştım, iyi ki süre dolmadan yetiştim...
« Yanıtla #9 : 23 Ekim 2016, 16:29:56 »
Şadan bey, sanırım ben bu anten ve propagasyon sorununu benim FT857 yi arabaya monte ederek mobil çalışmak suretiyle çözeceğim. Arabam çok eski, güvenlik sorunu var, cihazı arabada bırakırsam kesin yürütürler diye korka korka bugüne kadar geldim ama bu propagasyonla gerçekten araba ile dağa çıkıp çalışma ihtiyacım var. Artık balkon anteni hiç işe yaramaz oldu. Sanırım oto teyp montajcısı tanıdıkları "çok özel bir montaj" için ziyaret etme vaktim geldi. Onlar kızaklı bir montaj çözümü ayarlasın, anten işini ben kendim hallederim. Arabaya mıknatıslı tabanlık ile beraber tek bant HF anten takabilirim. Paralı bir anımda ATS 120 alıp taktırabilirim. Daha iyisi, gittiğim yerlerde geçici olarak tam dalga dipol hatta balık oltası gibi antenler de çekebilirim. Şu anda tek çıkış yolum bu gibi duruyor.
Çevrimdışı TA2TC
« Yanıtla #10 : 23 Ekim 2016, 19:08:54 »
Log yüklemesi yaptım ama hakem heyetinin kararı sonucu kabul edilecek diyor. Bekleyeceğiz artık.
« Yanıtla #11 : 23 Ekim 2016, 20:13:11 »
m
« Yanıtla #12 : 23 Ekim 2016, 20:38:11 »
Mete hocam her yıl  cihazı 100tl gibi bir fiyata kaskoya dahil ediyorlar . Ben çözümü böyle buldum .73
Çevrimdışı TA3MHA
« Yanıtla #13 : 23 Ekim 2016, 21:24:20 »
Mesut bey,
Bizim cihazlarımız yaygın, bilinen cihazlar olmadığı ve oturmuş 2. Piyasası da olmadığı için risk gerçekleştiğinde büyük hayal kırıklığı yaşayabiliriz.
Biliyorsunuz, sigorta yaparken cihazları beyan ettiğiniz fiyattan sigortalıyorlar ama iş ödemeye gelince kılı kırk yarıp 2. el fiyatından ödeme yapıyorlar.
En güzeli eşeği sağlam kazığa bağlamak bence
73 de ta3mha Ateş
Çevrimdışı TA2ANL
« Yanıtla #14 : 23 Ekim 2016, 22:36:13 »
Mete bey,
Merhaba. Anten tuner'iniz varmı? Eğer varsa size portable askeri vertikal antenlerden ayarlayayım.
Anten tuner ile çok iyi sonuç alırsınız.
Tolga
« Yanıtla #15 : 24 Ekim 2016, 00:25:41 »
Şartlar çok kötü olmasına rağmen 52 diğer , 17 UK/EI  73 AliM TA4AKS.
Çevrimdışı TA2L
« Yanıtla #16 : 24 Ekim 2016, 04:26:09 »
Son durum
« Yanıtla #17 : 24 Ekim 2016, 22:28:33 »
TA1API   DX   26   Sun Oct 23 20:39:14 BST 2016
TA1CH   DX   4   Sun Oct 23 09:58:30 BST 2016
TA2ACW   DX   17   Sun Oct 23 17:07:04 BST 2016
TA2ANB   DX   61   Mon Oct 24 12:56:59 BST 2016
TA2ANL   DX   12   Sun Oct 23 16:08:48 BST 2016
TA2DX   DX   2   Sun Oct 23 19:26:27 BST 2016
TA2LP   DX   12   Sun Oct 23 14:10:55 BST 2016
TA3ABM   checklog   56   Sun Oct 23 13:37:53 BST 2016
TA3EP   DX   5   Sun Oct 23 14:18:01 BST 2016
TA3MHA   DX   75   Sun Oct 23 14:25:41 BST 2016
TA4A   DX   11   Sun Oct 23 10:59:36 BST 2016
TA4AKS   DX   69   Sun Oct 23 22:19:41 BST 2016
TA4SO   DX   20   Sun Oct 23 20:29:21 BST 2016
TA5FA   DX   7   Sun Oct 23 18:11:03 BST 2016
TA7EB   DX   11   Mon Oct 24 07:11:00 BST 2016
« Yanıtla #18 : 07 Kasım 2016, 22:55:11 »
Sonuçlar;
« Son Düzenleme: 07 Kasım 2016, 22:56:54 Gönderen: TA5FA »
