Gönderen Konu: Dutch PACC CONTEST CW-SSB 2022  (Okunma sayısı 4141 defa)
« : 07 Şubat 2022, 22:29:31 »
HOLLANDA DUTCPACC YARIŞMASI CW-SSB
SADECE HOLLANDA İSTASYONLARI İLE GÖRÜŞEBİLİRSİNİZ.
1.Contest sponsoru
VERON
2.Contest Zamanı
12 ŞUBAT 1200 UTC, 13 Şubat - 1200 UTC,
160, 80, 40, 20, 15, 10m CW-SSB
3.Kategoriler:
•Diğer Ülke istasyonları;
•SINGLE-OP ALL HIGH CW,Single Op, All Bands, CW
•SINGLE-OP ALL LOW CW,Single Op, All Bands, CW, Low Power ≤100 watts
•SINGLE-OP ALL HIGH SSB,Single Op, All Bands, SSB
•SINGLE-OP ALL LOW SSB,Single Op, All Bands, SSB, Low Power ≤100 watts
•SINGLE-OP ALL HIGH MIXED,Single Op, All Bands, MIXED,
•SINGLE-OP ALL LOW MIXED,Single Op, All Bands, MIXED, Low Power ≤100 watts
•SINGLE-OP ALL QRP MIXED,Single Op, All Bands, MIXED, QRP ≤5 watts
•Hollanda istasyonları;
•A. SINGLE-OP ALL HIGH CW,Single Op, All Bands, CW
•A1. SINGLE-OP ALL LOW CW,Single Op, All Bands, CW, Low Power ≤100 watts
•B. SINGLE-OP ALL HIGH SSB,Single Op, All Bands, SSB
•B1. SINGLE-OP ALL LOW SSB,Single Op, All Bands, SSB, Low Power ≤100 watts
•C. SINGLE-OP ALL HIGH MIXED,Single Op, All Bands, MIXED,
•C1. SINGLE-OP ALL LOW MIXED,Single Op, All Bands, MIXED, Low Power ≤100 watts
•D. MULTI-ONE ALL HIGH MIXED,Multi Op, Single transmitter, MIXED
•D1. MULTI-TWO ALL HIGH MIXED,Multi Op, Two transmitters, MIXED
•E. MULTI-UNLIMITED ALL HIGH MIXED, Multi Op, All Bands, Multiple transmitters, MIXED
•F. SINGLE-OP ALL QRP MIXED,Single Op, All Bands, MIXED, QRP ≤5 watts
•G. SWL ALL MIXED,Single Op
•N. SINGLE-OP LIMITED LOW MIXED NOVICE TECH, Single Op, All Bands, MIXED,
Not: Geçerli Cabrillo örneklerine web sayfasından bakabilirsiniz.
1.8 -28 MHz, arasında tüm bandlarda (WARC bandları hariç) çalışılabilir, fakat aynı hafta diğer yarışmalara enterferans yapılmamalıdır.
Lütfen IARU 1. Bölge contest frekans aralıklarını kullanınız.
CW: 1810 - 1840, 3500 – 3560, 7000 - 7040 and 14000 - 14060 kHz
SSB: 1840 – 1880, 3600 - 3650, 3700 – 3800, 7060 – 7100, 7130 - 7200 ve 14125 - 14300 kHz
3.1 Tek Band katılım yapıp yarışma sırasında diğer bandlarda da QSO yapan katılımcılar diğer bandlardaki QSO ları sadece kontrol işlemine yardımcı olmaktadır.
3.2 Tüm katılımcılar Hollanda ve Dünya katılımcıları olarak ayrı değerlendirilir.
4.Bölge sıralaması
4.1 VERON Bölgeleri arasındaki ayrımı belirtir Hollanda istasyonlarını ilgilendirir
5.Genel Kurallar
5.1 Vericiler ve alıcılar 500 metre çapında bir daire içinde yer almalıdır. Bir katılımcı tarafından kullanılan tüm antenler alıcılara ve vericilere fiziksel olarak bağlı olmalıdır.
5.1.1 Tüm kategorilerdeki katılımcılara Cluter kullanımına izin verilir.
5.1.2 Self-spot yapılmasına yarışma sırasında izin verilmez. Yarışma sırasında telefon, teleks, internet, paket veya posta ile kişilerden bilgi talebi yapılamaz.
5.2 Tek Operatör katılımcıları kısıtlama olmaksızın bantları ve modları değiştirebilir. Sadece bir sinyal, herhangi bir zamanda havada olmalıdır.
5.2.1 Tek Operatör: Bu bir (1) kişidir, tüm işletme, log tutma işlerini ve spot fonksiyonlarını gerçekleştirir
5.3 MIXED (Karışık mode) kategorilerinde band başına aynı istasyon ile CW ve SSB modlarında QSO yapılabilir.
6.QSO Değişimi:
6.1 Diğer Ülke istasyonları: RS(T)+ 001'den başlayan seri numarası
6.1.1 Diğer Ülke istasyonlarında Çok operatörlü biden fazla Radyo kullanan kategori katılımcıları her band için ayrı seri numarası kullanabilir. Tek Radyo kullananlar tek seri numarası bloğu kullanılacaktır.
6.2 Hollanda istasyonları : RS(T) + İki karakterli bölge kodu vereceklerdir.
12 ayrı bölge kodu vardır: GR, FR, DR, OV, GD, UT, NH, ZH, NB, LB, ZL, FL
7.QSO Puanları.
7.1 Diğer ülke istasyonları ile Hollanda istasyonları arasında yapılan her geçerli QSO 1 puan sayılır. Hiçbir çapraz mode veya çapraz band QSO ları kabul edilmeyecektir.
8.Dupe (Aynı band da aynı mode'da çift QSO)
8.1 Dupe aynı bantta aynı istasyonu ile yapılan QSO'lardır. İki Istasyon arasındaki ilk QSO geçerli ise, dupe(ikinci QSO) 0 puan değeri var. Ilk QSO geçerli değilse, ikinci (dupe) QSO kabul edilir.
8.2 Dupe QSO'lar cezaya tabi değildir; Log üzerinde Dupe QSOları işaretlemek zorunda değilsiniz. Ayrıca, katılımcıların Dupe QSO ları Log üzerinde varsa kesinlikle silmemeleri tavsiye edilir,
9.Çarpanlar
9.1 Mode 'dan bağımsız her band da ilk Hollanda bölgesi ile yapılan QSO çarpan olarak sayılır.
Hollanda Bölge kısaltmaları listesidir:
DR = Drenthe NB = Noord-Brabant
FL = Flevoland NH = Noord-Holland
FR = Friesland OV = Overijssel
GD = Gelderland UT = Utrecht
GR = Groningen ZH = Zuid-Holland
LB = Limburg ZL = Zeeland
10.Sonuç Skor
Diğer Ülke istasyonları: QSO puanları toplamı ile Çarpanlar toplamının çarpımına eşittir.
Hollanda istasyonları: Ülke DXCC toplamları ile QSO puanları toplamlarının çarpımına eşittir.
11.Genel Log gönderim gereksinimleri
Her katılımcı Cabrillo formatında elektronik olarak log göndermelidir
11.1 Genel geçerli büyük log programları bu yarışmada kullanılabilir.
11.2 Tüm kayıtların zamanı UTC olmalıdır.
11.3 Tüm gönderilen ve alınan QSO değişimleri kayıt edilmelidir.
11.4 Log dosyası ismi <çağrıişaretiniz.log> yada <çağrıişaretiniz.cbr> olmalıdır
12.Log gönderi adresleri ve yöntemleri
12.1 Tüm Log lar 01 Mart 2022 tarihinden önce gönderilmelidir.
12.2 Log'lar E-posta yoluyla teslim edilmelidir: pacc@dutchpacc.com veya https://www.veron.nl/pacc http://server4.veronict.nl:81/WebEditor/app aracılığıyla yüklenebilir.
"Konu:" satırı istasyonu çağrı işareti ve kategori bilgisini yazdığınızdan emin olunuz Örnek: "TA3EP SOAB CW HP" E-posta yoluyla alındı bildirimi gönderilecektir.
13.Ödüller:
13.1 Hollanda istasyonları ............. .........
13.2 Diğer Ülke istasyonları: 25 ve daha fazla QSO yaptığınız takdirdi sertifika ve Liyakat belgesi olarak token of merit gönderilecektir.
Detaylı bilgi adresi: https://www.veron.nl/vereniging/commissies-en-werkgroepen/traffic-bureau/hf-contesten/pacc-contest/
Katılımınız TA katılımımızdır.
« Son Düzenleme: 09 Şubat 2022, 22:50:09 Gönderen: TA5FA »
Ynt: Dutch PACC CONTEST CW-SSB 2022
« Yanıtla #1 : 15 Şubat 2022, 17:21:56 »
Ali hocam benim çağrı kodumu örnek olarak vermişsiniz, teşekkür ederim. CW dinlemem henüz yarışma seviyesine gelmedi, bu nedenle yarışmaya SSB olarak katıldım. 26 QSO m var, umarım sertifikaya hak kazanmışımdır. 73
« Yanıtla #2 : 18 Şubat 2022, 23:40:31 »
Mete hocam teşvik teşvik...Selamlar ve saygılar sunarım ...
Çevrimdışı TA2BS
« Yanıtla #3 : 18 Şubat 2023, 15:00:28 »
